 Post subject: How Can I change Text Color?
PostPosted: Fri Jun 16, 2017 12:32 am
I am not sure just what my wife did but we have Winstep Xtreme. At some point her text color changed in her menu(s) and can just not be read. Nothing seems to fix it. It does not seem to be a Windows 10 issue. Her Winstep Background theme is Evolve which is a dark background. However, instead of white text it is now black! We need to make it black again. What am I missing?
If it ain't broke, fix it 'til it is.
 Post subject: Re: How Can I change Text Color?
PostPosted: Fri Jun 16, 2017 1:20 am
Menus only?
Ok, try this: open NextSTART Preferences, go to the Themes tab. Now click the Fonts button at the bottom left. In the dialog that pops up, select 'Menu Buttons'. What is the text color set to?
PostPosted: Fri Jun 16, 2017 1:37 am
Menus only?
She had tried that but I will look again.
PostPosted: Fri Jun 16, 2017 1:41 am
You have to make sure you do this in NextSTART Preferences, not WorkShelf Preferences.
If that's not it, there are a couple of other things we can look at.
PostPosted: Fri Jun 16, 2017 2:21 am
OK...Nextstart is now OK. How can she fix Workshelf and DOCKs?
PostPosted: Fri Jun 16, 2017 2:25 am
Eheh. Open WorkShelf Preferences, go to the Themes tab. Now click the Fonts button at the bottom left. In the dialog that pops up, check the colors of the different text items.
Not much difference. The real question is: how did she (or someone else) change them in the first place? :P
PostPosted: Fri Jun 16, 2017 5:34 pm
Thank you so much, as it seems that almost everything is back to "normal". As to what she did to mess it up is anyone's guess! :D
One last issue (I HOPE) is that she had a dock on top of her screen and then decided to remove it. That is OK, but her screen is still reserving that area and it is now blank and software like Firefox, etc will not go into that space. Every option she has tried to let an app use that space does not work. So, do you know where that setting is or did she break something else?
Thank you so much for your help!
PostPosted: Fri Jun 16, 2017 8:15 pm
my stab in the dark is that there could be an hidden or empty-invisible dock there?
there is a list of all docks in docks &shelves tab of nexus properties
http://prntscr.com/fknlfs
and it tells you where each dock is docked and how many icons does it have
PostPosted: Fri Jun 16, 2017 8:26 pm
Yeah, my guess would also be that instead of disabling or deleting the dock in Docks & Shelves tab of WorkShelf Preferences, she simply set it to fully transparent in the dock's own Properties dialog.
PostPosted: Fri Jun 16, 2017 8:56 pm
Thank you, I will look.
PostPosted: Fri Jun 16, 2017 8:58 pm
Let us know. :)
Users browsing this forum: Amazon [Bot], Apple [Bot], Bing [Bot], GPT [Bot] and 52 guests
