 Post subject: [solved] problems
PostPosted: Fri Mar 03, 2017 1:47 pm
Hello, I meet some problems
- media buttons do not work with JRiver Media 21.0.90. My keyboard media control buttons are working well with JRiver Media.
- alarm message in digital mode is unreadable - see capture
Have a good day.
 Post subject: Re: problems
PostPosted: Sat Mar 04, 2017 3:11 pm
The Media Buttons only support WinAmp and Windows Media Player.
Well, difficult to read, sure, unreadable, no. But that's the problem with LCD fonts, at smaller sizes they are difficult to read - using a non-LCD font would break the illusion that you are looking at an LCD Panel.
I'll look into this to see what can be done to improve readability (if anything) but until then you can either set the Alarm to appear full screen in LCD mode, or you can use a non-LCD mode.
PostPosted: Sat Mar 04, 2017 3:26 pm
OK, thanks for quick answer. The digital alarm is cool :-) and I will manage it. Too bad for the media buttons (I'm a little surprised they cannot be "generic").
 Post subject: Re: [solved] problems
PostPosted: Sat Mar 04, 2017 3:33 pm
Those were implemented YEARS ago, back when keyboards did not have MM keys.
I haven't revisited that code since then, so maybe there's now some standard... I'll look into that as well. :)
PostPosted: Mon Mar 06, 2017 8:16 pm
There are. Check this:
https://msdn.microsoft.com/en-us/library/windows/desktop/dd375731(v=vs.85).aspx
and this:
http://www.computer-engineering.org/ps2keyboard/scancodes2.html
I had somewhere a more full table that I used on a Teensy project, where I wrote some code to interface a classic Mac Plus keyboard to USB, but can't find it right now. Let me know if you need it.
Users browsing this forum: Amazon [Bot], Google [Bot], GPT [Bot] and 58 guests
