 Post subject: Flip Calendar???
PostPosted: Fri Jan 27, 2017 5:38 pm
Does the Flip Calendar work? Or is that a future enhancement. I set it to flip calendar bur it never goes to a flip calendar.
 Post subject: Re: Flip Calendar???
PostPosted: Fri Jan 27, 2017 6:37 pm
What exactly are your expectations? And are we talking about the iconic or desktop module?
PostPosted: Fri Jan 27, 2017 7:45 pm
Instead of a full month calendar, I was expecting the day as in the pic to show.
PostPosted: Sun Jan 29, 2017 2:20 pm
I think TheDude23112 is looking for an option for the calendar to show like this
http://prntscr.com/e1t67o
which i cant find ether
also these options: http://prntscr.com/e1t5lx don+t seem to do anything
PostPosted: Sun Jan 29, 2017 5:20 pm
Hmmmm, I had no problem setting up my flip calendar. And the options Seeker mentions work fine for changing colors, etc.
PostPosted: Sun Jan 29, 2017 5:28 pm
Right click on your full month calendar module and select "Display as Icon".
PostPosted: Sun Jan 29, 2017 5:34 pm
Thx, didn't think of searching for that in context menu
PostPosted: Sun Jan 29, 2017 5:45 pm
You guys don't follow the 'What's new in this release?' link in the Update Manager, or don't read it all, and then this happens. :)
Normally a desktop module will assume the look (and style) of it's iconic little brother if the current theme has no skin for it, or (recent addition) if you deliberately specify 'No Theme' for it.
However, a *desktop* calendar is pretty much useless if all it can do is show you what day it is *today*. For that you have the iconic version.
So, the calendar *desktop* module is unique in that it is the only desktop module that will actually show a default fully functional 'skin' even when none exists for it in the currently selected theme (and, with the calendar module being so new, no existing theme has skins for it, period).
This allows it to be used as a real calendar, one where you can see which day of the week a particular day is, navigate forward and backwards in time, show scheduled clock alarm events, etc... This default skin even goes as far as matching the currently selected iconic style.
If you really want the desktop module to assume the iconic shape instead, then right click on it and select 'Display as Icon'. It will then behave exactly as the iconic version - and no, you won't be able to navigate forwards and backwards in time with it, because there is no room in the icon for arrows. This said, the flip-calendar in icon format WILL flip - at midnight of that day.
Thanks, Douglas. :)
Users browsing this forum: Amazon [Bot], GPT [Bot] and 100 guests
