 Post subject: Restore settings 'missing theme' issue
PostPosted: Wed Jan 25, 2017 8:51 pm
Running latest Beta but not if its the issue with the beta or before
I have CPU/RAM meters set to theme:none
http://prntscr.com/e0bqc8
but when i restore my settings i get this error:
http://prntscr.com/e0bnfj
and the modules reset to aero lowres theme
 Post subject: Re: Restore settings 'missing theme' issue
PostPosted: Thu Jan 26, 2017 3:24 am
Well spotted, thanks. Issue has been there (unspotted or unreported until now) since it became possible to set the themes of modules to None.
PostPosted: Thu Jan 26, 2017 1:49 pm
glad to be of help, must have triggered it when i set it to none while checking for the net meter z-order/transparency issue
PostPosted: Thu Jan 26, 2017 8:04 pm
Subtle reminder, well played, it worked lol.
However, I'm not sure I understand what you mean by 'selecting the RAM Meter'
PostPosted: Thu Jan 26, 2017 9:15 pm
When you click on it or right-click
well it has been a circular trip of issues, i discovered this because i had been loking into the transparency issue, which i wouldn't have found out if i wasnt looking for a workaround for the flicker when docks/modules are set to be on bottom
PostPosted: Thu Jan 26, 2017 9:17 pm
Not able to reproduce it here then.
What are your settings for the Desktop RAM Meter module?
PostPosted: Thu Jan 26, 2017 9:28 pm
both modules are at 75 % size, and were at 70% transparency (i changed it to 69% to test if it would affect the issue)
no colorization and same (default) blur settings, nothing enabled under more options ether, under RAM meter setings its set to filled histogram with
( i think) default clour
i can send you my settings backup again
PostPosted: Thu Jan 26, 2017 9:31 pm
if they weren't placed one under another, and i wasn't so obsessive about the modules matching i probably wouldn't notice (don't ask me how much effort went to aligning them just right)
PostPosted: Fri Jan 27, 2017 8:34 am
Lol...
Unfortunately I still can't reproduce it here. And I just run out of time for this release. :(
PostPosted: Fri Jan 27, 2017 11:29 am
Lol...
Ok this one is on me, tinkered a bit and found out what it is, its because there is something off with my email icon, it has a large area of transparency so when RAM meter z order is normal it overlaps with that (when RAM module is over the transparent email module area it gains a shadow that makes it darker, when email module is on top the shadow disappears)
http://prntscr.com/e0zh2i
i don't remember exactly why i made it that way, i think it was the only way i managed to get the Font size right for it (i used Cabal extreme theme as base and modified the icon)
PostPosted: Fri Jan 27, 2017 11:36 am
similar shadow can be seen if you place a module in the area where shelf extends if the module is 'above' the shelf (*only when that module is transparent)
http://prntscr.com/e0zkfk
http://prntscr.com/e0zkxe
edit: the 'shadows' are visible even when the transparent object is something other than winstep
http://prntscr.com/e0zouk
(in this picture workshelf, email checker and net module give of 'shadow' on transparent GOM player, though transparent docks do not)
PostPosted: Fri Jan 27, 2017 11:58 am
To 'grab' mouse pointer movements over them, the screen objects (docks, etc...) cannot be 100% invisible. Those areas around them are 99.9% transparent, enough not be seen by the naked eye but also enough for Windows to pass mouse movements to the window underneath.
When you start combining alphas, however, that can happen. :)
Anyway, v17.1 is now officially released and just in the nick of time, go grab it.
PostPosted: Fri Jan 27, 2017 12:55 pm
yea, once when i figured out whats happening i realized it wasn't a bug, though, mouse doesn't react to those areas around the module icons, and the shadow doesn't appear over the transparent docks. If the modules weren't placed just exactly the way they are i would have realized whats going on sooner
Nice
Users browsing this forum: GPT [Bot] and 37 guests
