Board index : Winstep Forums : General Discussion  [ 32 posts ] Go to page Previous  1, 2, 3  Next
 Post subject: Re: Winstrep Xtreme 16.12 Fonts Folder - Question
PostPosted: Tue Jan 17, 2017 2:20 am
after restarting without workshelf on autostart i was able to delete fonts, but i didn't delete them all, then i turned autostart back on and restarted again, and was still able to delete the rest of the fonts
so, at least on my system, the files are locked only during the session in which winstep is installed (i believe i haven't restarted since reinstalling 16.12 following the installation of K-Lite)
PostPosted: Tue Jan 17, 2017 2:53 am
Ok, that at least makes perfect sense in relation to what MS is saying in that 2014 security update.
The font files in the AutoInstall folder are originally accessed by the Winstep application to copy and install them into the Windows Fonts folder, and, because of that, the system locks them until you reboot. Since the files are now locked by the system, they can no longer be deleted by the Winstep application right after copying them to the Windows Fonts folder (the delete operation silently fails with an 'Access Denied' error).
On the next reboot the files can be deleted, but since they are no longer a valid file extension for the AutoInstall mechanism, they are simply ignored by the Winstep application, and therefore linger around.
Now it makes sense. Thanks once again! :)
PostPosted: Tue Jan 17, 2017 3:04 am
glad to have been of help
PostPosted: Tue Jan 17, 2017 3:19 am
You were. :)
One oddity remains, however, at least regarding the original poster's situation.
Some of the folders and files are created by the setup application directly (InnoSetup), and these are automatically removed when uninstalling.
This, however, is not enough. The application itself will create folders the setup application knows nothing about, and over time the user will also install new themes into the Themes folder.
Because setup knows nothing about these files and folders, they would normally be left behind when uninstalling.
To prevent this, the uninstall program first runs the Winstep application with a special command line switch. It's the Winstep application and not setup that asks the user if he wants to delete all his settings and all his theme files. It is also the Winstep application that removes all traces of folders and files created by it and which setup knows nothing about.
One of the folders that gets deleted this way is the AutoInstall folder. So, the only way I see for it and the TTF files to linger around after uninstall is if the user tries to uninstall the Winstep application in the same session that he installed it, i.e.; without rebooting the system in between.
PostPosted: Tue Jan 17, 2017 6:02 am
There's (among many other all over the web) a 4 page thread HERE regarding Adobe Acrobat Reader suffering from this same problem because of the Microsoft's security fix KB2993651 that is described in bulletin MS14-045.
I especially liked how one user there summed up the problem:
"It looks as if this is working exactly as Microsoft intended. Adobe Reader makes temporary fonts for good quality and fast printing, using methods Microsoft have recommended for over 15 years. Adobe Reader then cleans up the fonts, but Microsoft in their wisdom stop the fonts from being deleted until the session has finished (by which time Adobe Reader cannot, by definition, be running to delete them). It's hard to imagine what planet Microsoft were on when they decided this was a good solution to whatever the problem was."
So there you go, Restorator... your complaint about this issue is better directed at Microsoft. Not that I think they will listen... the whole company seems to have lost their marbles lately.
PostPosted: Tue Jan 17, 2017 6:04 pm
Hello Winstep 8)
I installed Windows 7 SP (x64) again. It's a clean installation with all updates to date.
The problem persists:
- Fonts are displayed correctly in the Registry
- Fonts are displayed correctly in the Fonts folder
- Fonts remain locked in the AutoInstall folder (System Process ID: 4)
I tried LockHunter application that can remove the fonts after the restart, but it is not the solution for me.
See screenshots 1,2.
I tried to look for some utilities to process in Windows.
I found the utility from the developer's of Microsoft.
https://technet.microsoft.com/en-us/sysinternals/bb795533
I tried some of them, and Process Monitor v3.31 provides some much information as possible to determine the problem.
https://technet.microsoft.com/en-us/sysinternals/processmonitor
- I installed the program Winstep Xtreme again. The program I started and then I uninstalled it.
- In location C:\Users\Public\Documents\Winstep\AutoInstall remained fonts. OK.
Try this:
After running the program Process Monitor press Ctrl+F and search string: eg. HOOG0553.ttf
- The first result is finding QueryDirectory and some PID, eg. PID: 2024 (PID is always changing)
- Press F3 again and again and watch Time and Operations items (eg. CreateFile, QueryStandardInformationFile, CreateFileMapping etc.)
- In Operation (CreateFileMapping) you'll see in (Result) that FILE LOCKED WITH ONLY READER - see screenshot 3
- right click on file and select Properties (on each tab you'll see more details)
You will find probably more information about the problem.
I want to try one more solution using the installer. When this fails, then I do not know :wink:
File comment: screnshot 3
File comment: screnshot 2
File comment: screnshot 1
Operating System: Windows 7 (x64) SP1
Procesor: Intel(R) Core(TM) i7-4790 CPU @ 3.60 GHz
RAM: 16.0 GB
Graphics Card: NVIDIA GeForce GTX 960
Screen Size: 1920 x 1080 px, 60 Hz
Last edited by Restorator Winstep on Wed Jan 18, 2017 11:20 am, edited 2 times in total.
PostPosted: Tue Jan 17, 2017 6:12 pm
Sorry, but this post I have seen before.
RAM: 16.0 GB
PostPosted: Tue Jan 17, 2017 6:14 pm
Thanks for the detailed info, but did you read all that me and Seeker wrote above?
This is a Microsoft Windows issue, not Winstep's.
STATUS_FILE_LOCKED_WITH_ONLY_READERS indicates that the file was locked and all users of the file can only read. And who is locking the font files? Windows via Explorer.exe, not the Winstep application.
This is the result of a Microsoft's half-baked (as many of them seem to be these days) security 'fix'.
I strongly suggest you read a 4 page thread HERE regarding Adobe Acrobat Reader suffering from this same problem, and the solutions presented there (which basically comes to uninstalling the security update(s) that cause this problem).
Never-the-less, rebooting your system should allow you to delete the font files in the AutoInstall folder.
PostPosted: Tue Jan 17, 2017 6:22 pm
Maybe you could ad some sort of log when installation process is denied access to delete files after reboot (similar as Revo uninstaller/unlocker/AV apps delete the files they cant unlock during session), some run once autostart that deletes the files installation loged as unable to delete?. but i have no idea how hard would that be to implement
PostPosted: Tue Jan 17, 2017 6:24 pm
Yes, I read these posts. That's why I wrote that I apologize. (comment above: Sorry, but this post I have seen before.)
RAM: 16.0 GB
Last edited by Restorator Winstep on Tue Jan 17, 2017 6:38 pm, edited 1 time in total.
PostPosted: Tue Jan 17, 2017 6:26 pm
Guess we cross-posted lol
PostPosted: Tue Jan 17, 2017 6:32 pm
The setup/uninstall application (InnoSetup), as all installers, would *probably* be able to do something like that. However, those TTF files were not placed there by the installer itself, so it knows nothing about them and will not even try to delete them.
Anyway, thing is, if you reboot before uninstalling the Winstep application (i.e.; if you don't install and uninstall in the same session), this should be a mute problem, as those TTF files should no longer be locked by the system then.
PostPosted: Tue Jan 17, 2017 6:48 pm
You're absolutely right.
RAM: 16.0 GB
PostPosted: Wed Jan 18, 2017 8:05 am
Hello Winstep ...
In my opinion there is no problem input installed fonts directly into the installer.
I compiled my own installer into which I put only one GothicFlames font. Everything works correctly.
I think that this is a better solution than packing fonts into archive ns3-thms.zip.
Inno Setup Documentation: http://bit.ly/2j8gG6V
Part of the code in the program Inno Setup Compiler:
FontInstall - This must be exactly the same name as you see when you double-click the font file.
onlyifdoesntexist - Only install the file if it doesn't already exist on the user's system.
uninsneveruninstall - Never remove the file. This flag can be useful when installing very common shared files that shouldn't be deleted under any circumstances, such as MFC DLLs.
Code:
[Files]
Source: "{fonts}\GothicFlames.ttf"; DestDir: "{fonts}"; FontInstall: "Gothic Flames"; Flags: onlyifdoesntexist uninsneveruninstall
Here is the full script for compilation: - Stop Adblock or continue!
http://bit.ly/2k3yRi2
Here is a compiled installer: - Stop Adblock or continue!
http://bit.ly/2jxSnlQ
For simplicity, I recommend the following configuration script folders for the installer Inno Setup of the program Winstep Xtreme:
Code:
{app} - all folders and files in Program Files (x86) or in Program Files
{commondocs} - all commondocs folders and files with "ns3-thms.zip" file
{fonts} - all of 13 type fonts
{sys} - all system files
embedded - WizardImage.bmp, WizardSmallImage, License.txt, Languages.isl
SetupIcon.ico - Installer icon
Everything will definitely work properly in different operating systems and will not be a problem with fonts that are locked in Windows 7. :idea:
RAM: 16.0 GB
PostPosted: Wed Jan 18, 2017 11:48 am
I want to ask you to correct Topic title from "Winstrep" to "Winstep", if it's possible.
Thank's
RAM: 16.0 GB
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 32 posts ] Go to page Previous  1, 2, 3  Next
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 127 guests
