Board index : Winstep Forums : General Discussion  [ 172 posts ] Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12  Next
 Post subject: Re: Winstep crashing since the latest update
PostPosted: Mon Jan 09, 2017 8:49 pm
what would be more useful to you, that i try replacing avast now, or to wait until you implement the fix?
Given that making a Proxy for playing MP3 is going to be a lot of work (and I will be REALLY pissed if that doesn't solve the problem lol) I feel really tempted to advise you to replace AVAST, but everything you've been describing so far seems related to the MP3 files, so chances are the culprit is a bad codec.
This said, the alarms in the previous version also played MP3 files and that one didn't crash... And if you run v16.12 with Avast it doesn't crash either... so...
I don't know. This is a tough one. On the other hand, making the Proxy won't hurt anything either (other than me wasting my time if that doesn't solve anything).
PostPosted: Mon Jan 09, 2017 8:50 pm
Yes it does, would that be enough to resolve the conflict?
Don't know. No idea how they implemented their code.
PostPosted: Mon Jan 09, 2017 9:00 pm
as i posted before, few days ago i tested 16.2 and 16.9 and they behave the same way with alarms, although i had to run couple alarms an hour to test it
its possible before i simply didn't use them often enough to cause the problems, or something on my system changed
PostPosted: Mon Jan 09, 2017 9:11 pm
Ah, ok, I didn't catch that. So it seems to be definitely related to MP3 files.
PostPosted: Mon Jan 09, 2017 9:29 pm
yes, but i cant tell if its a rare thing that doesn't occur unless you play the mp3 often, or did something change on my system since spring/summer when i last used alarm manager regularly
PostPosted: Tue Jan 10, 2017 1:28 am
i put winstep program files folder, as wel as users/public/documents/winstep folder as exceptions in avast, glich (memory error?) happened, same when i disabled avast shields
PostPosted: Tue Jan 10, 2017 6:48 am
I use Avira for my antivirus needs, and I've been very happy with it. It was one of the highest rated free ones when I installed it.
PostPosted: Tue Jan 10, 2017 7:24 am
Just to confirm one more thing, since you seem able to make WorkShelf break so easily with the alarms: what if you temporarily set the alarms not to play ANY MP3 files? No issues?
Just want to make sure it is indeed related to the MP3 files and not to the alarms themselves.
PostPosted: Tue Jan 10, 2017 7:28 am
haven't thought of that, enabled them with no multimedia file now, ill try a wav file later
PostPosted: Tue Jan 10, 2017 9:48 pm
So... any news?
PostPosted: Tue Jan 10, 2017 10:11 pm
no crashes so far without mp3 in alarms
PostPosted: Tue Jan 10, 2017 10:18 pm
Sigh.
Guess there's no escaping making the MP3 proxy then. lol
PostPosted: Tue Jan 10, 2017 10:39 pm
i can try uninstalling avast first or wait for the fix if you wish
PostPosted: Tue Jan 10, 2017 11:08 pm
Wait, if you don't mind... I should have the Proxy done by tomorrow night.
PostPosted: Tue Jan 10, 2017 11:10 pm
ill wait then :)
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 172 posts ] Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12  Next
Users browsing this forum: Apple [Bot], Google [Bot] and 13 guests
