Board index : Winstep Forums : General Discussion  [ 47 posts ] Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: WS Xtreme installhas gone completely borked. Very messed
PostPosted: Sat Nov 05, 2016 3:07 am
werewolf wrote:
This time, there are no themes listed in the themes tab.
1. Why? What did you change/do in the mean time?
2. Look under
do you see a Themes folder there?
3. What about
C:\Users\<username>\Appdata\local\Virtual Store\Program Files (x86)\Winstep\
Does that folder exist? Does it have a Themes folder inside?
PostPosted: Sat Nov 05, 2016 3:40 am
The only thing that I did differently was when I uninstalled Winstep I included deleting these items which you suggested:
C:\Users\<username>\Appdata\local\Virtual Store\Program Files\Winstep\
Other than that, I haven't done anything different. An odd thing, the past few times, Icon Packager icons were missing also, this time they are not missing and all are displaying correctly. That's new. Windowblinds can't find its files.
C:\Program Files (x86)\Winstep has no themes folder.
C:\Users\<my user name>\AppData\Local\VirtualStore\Program Files (x86)\Winstep\ does have a themes folder, but there is nothing inside it.
PostPosted: Sat Nov 05, 2016 3:51 am
Exit Winstep Xtreme, delete
and run Winstep Xtreme. Let me know if the themes became visible again.
Also, please post a screenshot with the contents of the
D:\Public Documents\Winstep
and
folders.
PostPosted: Sat Nov 05, 2016 4:02 am
Done. Winstep cannot see the themes.
PostPosted: Sat Nov 05, 2016 4:20 am
I would *really* like to know how that Languages folder got inside
Hmmmm....
Ok, two things:
1. Can you please check if the
folder spontaneously came back? If so, can you please also post a screenshot of the contents?
2. Can you see your themes inside
D:\Public Documents\Winstep\Themes\ ?
PostPosted: Sat Nov 05, 2016 4:49 am
This is the theme which should be applied:
PostPosted: Sat Nov 05, 2016 5:05 am
Ok, that's not right at all!
The fact that you see that inside the VirtualStore folder means that the Winstep application is trying to write to C:\Program Files (x86)\Winstep\
Since it can't (Windows does not allow that since Vista), the folder gets 'virtualized' into the VirtualStore, so the application thinks it's writing under C:\Program Files (x86)\ when it really isn't.
The problem is that this should not happen at all. Winstep Xtreme will NOT try to write to C:\Program Files (x86)\Winstep\ at all unless it sees a Licenses and a Themes folder inside C:\Program Files (x86)\Winstep\ (in which case it will do it to preserve backwards compatibility with original installations going all the way back to XP).
Ok, lets try this again:
1. Exit Winstep Xtreme.
2. Delete the
folder again, but this time leave an Explorer window open inside
to see when the virtual Winstep folder gets created again.
Now do NOT run Winstep Xtreme. Go to
and launch workshelf.exe by double-clicking on it. Don't do anything with WorkShelf, just launch it. Watch what happens inside the VirtualStore folder and let me know your findings.
If the Winstep folder is not immediately created inside the VirtualStore folder at this point, then do whatever you've been doing with WorkShelf. Keep an eye on Winstep appearing in the VirtualStore folder again - let me know what happens.
PostPosted: Sat Nov 05, 2016 5:21 am
The Winstep folder immediately reappeared in .../virtualstore/program files (x86)/ when I double clicked workshelf.exe
PostPosted: Sat Nov 05, 2016 5:24 am
Ok, very strange... anyway, got to go get some sleep now, sorry...
We'll go on tomorrow.
There is another possibility for this happening: WorkShelf being unable to get a folder from CSIDL_COMMON_DOCUMENTS - but this would probably indicate a problem with Windows itself.
PostPosted: Sat Nov 05, 2016 5:30 am
No problem Jorge. Looks like it's almost 05:30 there. Go to sleep. I'll do this as long as you need to tomorrow.
PostPosted: Sat Nov 05, 2016 3:28 pm
I moved the documents folder back to its default location c:\users\public\documents.
When I booted back to my desktop, my theme was loaded correctly, but Workshelf showed no themes on the themes tab. The registry entries were pointing to the correct locations for the current theme.
I exited WS, deleted the Winstep directory from the virtual store and loaded WS.
The directory was NOT recreated in the virtual store and all my themes were back.
This is for the default public documents location, not D:\
PostPosted: Sat Nov 05, 2016 7:18 pm
Mind moving it back to D: to figure out what might be going on?
After moving to D: again, download THIS small test program I made, unzip into
and run TestPath.exe. Please post a screenshot of the results.
PostPosted: Sun Nov 06, 2016 5:38 am
Maybe I missed it somewhere, but did you try uninstalling WS completely, then moving the folder location, then reinstalling WS?
PostPosted: Sun Nov 06, 2016 5:48 am
Yes he did, that's not the problem.
I suspect the API calls to get the current location of the Public Documents folder fail if the user has moved it somewhere else. But I can only be sure after he runs that little test application and shares the results. :)
PostPosted: Mon Nov 07, 2016 3:16 am
Moved everything, did *nothing* else.
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 47 posts ] Go to page Previous  1, 2, 3, 4  Next
Users browsing this forum: Apple [Bot], winstep and 18 guests
