 Post subject: application window size (newbie question!)
PostPosted: Sat Jul 17, 2004 6:22 am
hi there. first, let me say that i LOVE nextstart. it's an amazing program.
is there a way to make applications such as IE and mozilla firefox take up the whole screen? i noticed when they're maximized they stop where the windows taskbar should be, even though it's not there. is that just how it is, or is there a way around that?
thanks!
PostPosted: Sun Jul 18, 2004 10:03 am
That's the Windows taskbar still reserving screen space.
Go to the Windows Taskbar properties before you run NextSTART (or, if you are running XP, go to Control Panel and open the Taskbar and Start Menu applet) and, in the Taskbar section, disable 'Keep the taskbar on top of other windows'.
Users browsing this forum: Google [Bot] and 72 guests
