 Post subject: [NEXUS Ultimate] 'Magnify Effect' Transparency Abnormality
PostPosted: Wed Sep 07, 2016 3:57 am
Recently I have noticed some kind of abnormal transparency mask surrounding my Nexus docks when using the 'magnify effect'.
(please watch the following video clip)
I have been using Nexus for quite a long time and never noticed any 'strange anomalies' like this one. It is clearly visible with almost every nexus theme I use with the magnify effect applied. I have gone through every possible setting within Nexus, as well as all of my nvidia display settings. Unfortunately nothing I try corrects this.
If anyone has any ideas as to what this is, and/or why this is happening, please let me know.
Thanks.
 Post subject: Re: [NEXUS Ultimate] 'Magnify Effect' Transparency Abnormal
PostPosted: Wed Sep 07, 2016 8:50 am
No worries, I know what it is. Thanks for the video, that made it clear.
PostPosted: Wed Sep 07, 2016 12:52 pm
Excellent Jorge :o
Please do explain...
Thanks.
PostPosted: Wed Sep 07, 2016 4:05 pm
The see-through dock background can't be 100% transparent because otherwise mouse clicks would fall through the 'holes' in the icons. It's supposed to be 99.9% transparent, in such a way that it's not visible to the naked eye but Windows still passes mouse clicks to the dock instead of whatever is behind it.
I must have changed something that has the side-effect of this 'transparent' part of the background actually becoming visible to the eye, in a ghostly way.
Since I know what it is, fixing it should be trivial. As soon as I get back to the office, that is. :)
PostPosted: Wed Sep 07, 2016 6:47 pm
Excellent.
I'm relieved that you know what's causing it.
And I hope it is indeed a simple fix.
Thanks again Jorge.
Please keep us posted.
PostPosted: Mon Sep 12, 2016 1:44 pm
Ok, now that I had a chance to look at the code, I can see that nothing has actually changed (I thought I might have changed a value when testing for something and then forgot to revert it), so I'm not sure why you are seeing that.
As I explained above, the area immediately behind the icons cannot be fully transparent. If it is, clicking on any part of an icon that is also fully transparent will make Windows send the mouse click to whatever window is behind the dock instead of the dock itself. Furthermore, mouse move events must also be trapped/sent to the dock when you mouse over it, otherwise the dock would de-magnify as soon as the mouse pointer reached a blank space between the icons.
Each pixel in the dock has an RGB color value PLUS an Alpha (transparency) value between 0 and 255. 0 means fully transparent (mouse clicks, etc, go 'through' it to whatever is behind) and 255 is fully opaque.
That 'mask' you are seeing there has an Alpha value of 1, the minimum you can actually give it to still catch mouse clicks. The actual color/RGB value when I first made Nexus was RGB(0,0,0), which is black. However, this did result in what you are seeing in the video, so I changed it a long time ago to RGB(255,255,255), which is white. This made the 'mask', as you call it, invisible to the eye.
Thing is, I can't see it here when magnifying the dock, no matter what background/wallpaper I use, so I don't know why you are seeing it there.
Now, you also state 'I have been using Nexus for quite a long time and never noticed any 'strange anomalies' like this one.' This kind of implies that it wasn't happening before. So what did you change?
PostPosted: Fri Sep 16, 2016 10:09 pm
:| Hmmm... ok, yeah.
And since there were no Nexus updates around this time,
my first thought was that this problem must be caused by something else within my system.
But I really don't know what else to check or troubleshoot.
I've gone through all my display settings and Nexus settings, and all of my drivers are up-to-date.
Unfortunately nothing I tried so far has helped.
Maybe I should uninstall and reinstall Nexus and see what happens.. or would that just be a waste of time?
If anyone has any ideas as to why this might be happening, Please let me know.. .
Thanks.
PostPosted: Fri Sep 16, 2016 11:59 pm
Sincerely, I think it would be a waste of time.
But (and I also think this will be a waste of time but at least not so bad) we never know if some obscure combination of settings is causing this, so you could try resetting your settings to factory defaults and see if that changes anything.
Preferences -> Advanced -> Troubleshooting Options -> Reset Everything.
Please don't forget to backup your settings first, so you can restore them later.
Users browsing this forum: Amazon [Bot], GPT [Bot] and 99 guests
