 Post subject: Winstep Miiddle-click Overrriding Browser Add-on
PostPosted: Thu Jun 30, 2016 10:51 am
Hi Jorge. I have a problem. I have an Add-on in Firefox called Add Bookmark Here. It's awesome!!
My problem is that I just changed a Add Bookmark Here setting to use a middle-click for one of its features but Winstep is overriding it and opens a context menu.
How do I disable that command? Did you move that setting or is it that it's been so long since I've fiddled with it is the reason I can't find it?
 Post subject: Re: Winstep Miiddle-click Overrriding Browser Add-on
PostPosted: Thu Jun 30, 2016 12:42 pm
Opens a *context menu* or a *NextSTART menu*?
My bet goes for the latter. If so, check your NextSTART hotspots.
PostPosted: Thu Jun 30, 2016 1:15 pm
Yes, NextSTART menu. Thanks, now I remember! Something else I now remember. The affected setting is under 01 NextSTART. Didn't you once say that 00 and 01 NextSTART in Hotspots has to be checked? Just want to make sure.
I changed the setting to Button in the Quick Launch Area even though I don't have one. Not sure, but I might add one at some point. The feature for Add Bookmark Here works now. :D
PostPosted: Thu Jun 30, 2016 1:44 pm
Nah, hotspot 0 is the critical one. Hotspot 1 is there so you can also access the NextSTART menu by bumping the top left screen corner.
PostPosted: Fri Jul 01, 2016 6:37 am
Hmmmmm, 00 is not set for the top left corner bump. It is set to Activated by=Hotkey Only and I don't have a hotkey assigned to it.
I have the top left corner bump assigned to open a folder. All of my bump options are used up.
So, with this new revelation, can I uncheck both 00 and 01 without any negative affects?
PostPosted: Fri Jul 01, 2016 1:30 pm
You can uncheck 01.
Users browsing this forum: Amazon [Bot], Google [Bot] and 58 guests
