 Post subject: recover settings
PostPosted: Tue Jun 21, 2016 4:15 pm
Hi forum,
is there a way to recover the Nexus settings directly from somewhere on the hard drive? I had to reinstall Windows and would like to restore Nexus to the state it was before, if this is somehow possible.
Thanks already
David.P
 Post subject: Re: recover settings
PostPosted: Tue Jun 21, 2016 5:38 pm
If you had previously made a backup of your settings, the answer would have been yes.
Now... I'm afraid not. Data is stored in the Windows Registry and that is gone.
PostPosted: Tue Jun 21, 2016 7:09 pm
I still have the damaged installation. I think I can extract the respective registry part and inject it into the new install!
PostPosted: Tue Jun 21, 2016 9:14 pm
Look under
HKEY_CURRENT_USER\Software\WinSTEP2000
then.
Users browsing this forum: Amazon [Bot], GPT [Bot], Majestic-12 [Bot] and 66 guests
