 Post subject: NextStart Menu
PostPosted: Thu Jun 09, 2016 9:03 pm
When i right click on the icon on the far right side of the task, I associate to NextStart Menu. Now when i click on that icon, nothing happens. If I associate to Windows start Menus, I do get the windows start menu. I can't seem to get the NextStart Menu.
Thanks for any help.
 Post subject: Re: NextStart Menu
PostPosted: Thu Jun 09, 2016 9:09 pm
Open NextSTART Preferences, go to the Hotspots tab and check what you have Hotspot #0 set to do. Make sure it's configured to open the NextSTART menu and is not disabled or anything like that.
PostPosted: Thu Jun 09, 2016 9:53 pm
Thank-you, thank-you, thank-you!!!!!!
Users browsing this forum: Majestic-12 [Bot] and 25 guests
