 Post subject: sub dock icon animation/slideshow
PostPosted: Mon Apr 25, 2016 3:43 am
is there a way to set a subdock to display the icons within the subdock, and change the icon say every 0.5second to the next icon in the subdock, etc
because i now have around 8 subdocks next to each other, and its hard to distinguish which is which without hovering the mouse to read the name of the subdock
 Post subject: Re: sub dock icon animation/slideshow
PostPosted: Mon Apr 25, 2016 4:14 am
No, but you can simply change each subdock's icon to an icon/image that reflects its contents: right click the sub-dock icon -> Dock Entry Properties -> Change Icon.
PostPosted: Mon Apr 25, 2016 4:58 am
also talking about icons, i mentioned caching to you before, but i think you did something different with this version of the software, i remember when i was on the trial software v14 i had external hdd shortcuts on the dock, but if i boot up windows without the external hdd the icons would change to the ? icon, this doesnt seem to be the case anymore, is it because once the icon is loaded it is stored in winstep library now?
if so i could change the icon in the subdock, and if the icons location changes will it still be in winsteps icon library?
PostPosted: Wed Apr 27, 2016 5:08 pm
No and no. :)
Users browsing this forum: Google [Bot] and 29 guests
