 Post subject: Keeping task bar same but only changing start menu...
PostPosted: Sat Nov 25, 2006 10:13 am
Hi, I would love to keep my task bar the same because it matches everything else I've put on this desktop over the time I've had it.. I was wondering if there was an option to allow me to just skin the start menu... And if not that would be very cool to have as an option.
PostPosted: Sat Nov 25, 2006 11:10 am
From what I understand you would like to 'lock' the theme for your Startbar, right?
While individual theme 'locking' is indeed a possibility for WorkShelf's desktop modules and docks, the NextSTART startbar is so interlated to the NextSTART menus that no such mechanism exists, sorry...
PostPosted: Sat Nov 25, 2006 12:03 pm
Its fine man, after about an hour i set up a cool little minimalistic view :) So this problem doesn't really apply anymore ^.^ thank you for taking your time to answer me though.
PostPosted: Sat Nov 25, 2006 12:13 pm
No problem, that's what I'm here for! :D
You're running the new Winstep Xtreme or the older Winstep Full Pak?
Users browsing this forum: winstep and 67 guests
