 Post subject: Re: Version 16.3 released.
PostPosted: Fri Apr 01, 2016 1:55 am
:oops: Didn't realize that they had separate versions. I thought all of the info was in NextSTART.
Here is the WorkShelf info. Is this up to date?
PostPosted: Fri Apr 01, 2016 2:57 am
Yes.
PostPosted: Fri Apr 01, 2016 12:21 pm
Should I send you my current settings to see if something in them is causing the problem? I figure if it doesn't do it on your PC with my settings that something outside of Xtreme is affecting that feature.
If it does, then hopefully you can find what change happened in the settings and then either you or both of us can figure out what caused it.
Oh BTW, which settings should I send so I don't send the wrong thing.
PostPosted: Fri Apr 01, 2016 1:09 pm
Never mind, figured out what is triggering this.
PostPosted: Fri Apr 01, 2016 1:47 pm
This was happening, in part, because you had the Shelf set to auto-hide too quickly. Anyway, it obviously shouldn't happen regardless of the auto-hide delay, so I fixed it.
PostPosted: Sun Apr 03, 2016 9:26 pm
Great! I'm glad you found the source of the problem. :D
I assume you used the settings I sent you some months ago. I wasn't sure if those would find the problem since the 16.3 update fixed the issue temporarily and why I inquired about sending my current settings.
Keep up the great work!
PostPosted: Tue Apr 05, 2016 9:47 am
Jorge, just so you know, my WorkShelf settings haven't changed. I made minor changes to other parts of Winstep since sending you my settings earlier, but wasn't sure if those had an affect on the delete issue.
 Post subject: Re: Version 16.3 released. DOWNLOAD HERE.
PostPosted: Sun Apr 10, 2016 7:47 pm
mudora23 wrote:
BUG:
-> Enable 'Open sub-dock on mouseover' with 0ms delay
-> Quickly mouseover serveral sub-docks
-> Crashes workself
It is fixed while having even a slight delay. Tell me if you need more info.
I've been trying to reproduce this here without success, unfortunately. Tried difference sub-dock opening animations, tried increasing animation speed, still no crash.
Anything else you can tell me about this?
Users browsing this forum: Amazon [Bot], Apple [Bot] and 92 guests
