Board index : Winstep Forums : General Discussion  [ 20 posts ] Go to page Previous  1, 2
 Post subject: Re: CD/DVD no longer works
PostPosted: Mon Feb 15, 2016 6:17 am
Ok, thanks...
I'll make a new build some time soon to see if we can fix these problems.
PostPosted: Mon Feb 15, 2016 6:24 am
interestingly enough, after the reboot, it does it every time I click.
PostPosted: Wed Feb 17, 2016 7:30 am
I fixed the CD Control errors.
Also made sure that the command is ignored if you try to repeat it while the previous one is still being processed, and introduced a forced delay of 2.5 seconds between repeats. The hardware likes to take its time. :)
PostPosted: Sat Mar 12, 2016 1:16 am
Thank you, Works again. Whooo Hoo And I'm liking only having 1 icon to open close. Great work
PostPosted: Sun Mar 13, 2016 12:21 pm
Thanks! :)
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 20 posts ] Go to page Previous  1, 2
Users browsing this forum: Apple [Bot], Google [Bot] and 84 guests
