 Post subject: Cannot keep Nexus Toolbar on Top
PostPosted: Mon Nov 09, 2015 11:43 pm
As it says i'm struggling to keep Nexus toolbar on top of a program I use which insists on full screen coverage. It's ok for a few minutes but it gets knocked down a layer. There are no settings in the dominating program to stop it going 'full screen' and I have the correct options selected for 'stay above all other programs' in Nexus selected. Is there anything else I could do to help it stay on top? :?
thanks. Sean
 Post subject: Re: Cannot keep Nexus Toolbar on Top
PostPosted: Tue Nov 10, 2015 4:02 am
What do you call 'full screen'? A maximized window is a very different beast from a full screen app, and Nexus is designed not to interfere with full screen apps (so it doesn't pop up by accident when you're playing a game, for instance).
This said, you can try associating an hotkey to activate the dock (Behavior tab -> More Options). That way, whenever the other program fights with it for 'who's on top' status, you can simply press the hotkey to bring the dock forward.
Users browsing this forum: No registered users and 15 guests
