 Post subject: "Disable reflections when dock is vertical" issue
PostPosted: Sun Oct 04, 2015 9:20 am
Hi, after the recent automatic updates of Winstep Nexus Ultimate, there is a bug with the version 15.9, because the new option "Disable reflections when dock is vertical" doesn't work correctly.
I use a vertical dock and I like always enabled the reflections of the icons, but the problem is that removing the check to the item (in the "Appearance" tab), the setting is not retained.
To be precise, the settings are kept until you restart Winstep Ultimate, so every time I turn off the PC, or for some reason you restart the dock, the icons reflections disappear (that is, if you go in the apperance tab, the check on the item "Disable reflections when dock is vertical" is returned by default).
Also, the strange thing is that the manual settings (disabling this feature) never are retained in the backup: if you do a backup of all settings, with the reflections of the icons enabled, then after restarting the dock (so the reflections disappear), and recovering the backup, the result is still there are the default settings (the "Disable reflections..." check is activated :? ).
Can You solve this issue? Thank you.
My OS is Windows 7 Ultimate SP1 64-bit.
 Post subject: Re: "Disable reflections when dock is vertical" issue
PostPosted: Sun Oct 04, 2015 2:36 pm
Rats. Confirmed bug. I fixed it and will post here when you can download an update.
PostPosted: Sun Oct 04, 2015 3:00 pm
Ok, Jorge. Thanks for your work. :)
PostPosted: Thu Oct 15, 2015 8:32 am
Hi Jorge,
today I renewed the Nexus Ultimate subscription license.
However, at the moment there are not available software updates.
So, how can I get your fix?
Thanks.
PostPosted: Thu Oct 15, 2015 1:44 pm
Ooops, my bad, sorry Alvin.
You have a PM. :) :D
Users browsing this forum: No registered users and 57 guests
