 Post subject: Larger Magnify effect
PostPosted: Mon Oct 12, 2015 5:40 pm
Id love a larger zoom for the magnify effect, current is 255 pixels, if it could go up to 300 that would be perfect
Any chance of that in a update???
GAME DOCK ICONS MADE BY ME - http://30011887.deviantart.com/gallery/
PC SPECS - MSI GTX 980 GAMING 4G, I7 4790K @ 4GHZ, 12GB RAM, WINDOWS 10 PRO
 Post subject: Re: So, what's next after v15.9?
PostPosted: Mon Oct 12, 2015 6:05 pm
I don't think so, sorry.
Most original icon sizes don't exceed 128x128 pixels, although some will be 256x256. Magnified to 300x300 those icons would look extremely blurred.
PostPosted: Tue Oct 13, 2015 3:21 am
Thats ok,
i make icons for my games that are 512x512, also thats why i bought this program and recently renewed it last month, i only use it for games and emulator games but if that feature wont be ever getting added then this is last time im renewing for this program
Thanks anyway for this great program :)
PostPosted: Tue Oct 13, 2015 3:56 am
Sorry if you feel that way, since Winstep applications are about so much more than simply being able to display 300x300 icons.
I'm not going to be 'blackmailed' into adding features that only a single user has shown an interest in: it's a golden road to bloatware. :) I sincerely hope you're able to find another dock (or another way) to accomplish what you're looking for.
 Post subject: Re: 300x300 icons
PostPosted: Tue Oct 13, 2015 7:23 am
If I may weigh in, here, I fully support Jorge's attitude against "blackmail"; I think it's rather sad to say anything like "if you don't do this, I'm not buying".
Having said that, however, Jorge... I understand what you're saying, if we're talking about .ico files. But... Winstep does support .png files for icons, which can have any resolution, so they'll look perfectly fine in any size.
Plus... displays with ultra-high resolutions are becoming more and more common, nowadays. It's not uncommon for someone to have, say, a 23-inch monitor with a high DPI and a resolution of 2000+ horizontal pixels.
That's a lot of pixel density in a small physical area and from that perspective, 256x256 icons would look tiny.
Perhaps you could... I don't know... give it some further thought?
PostPosted: Tue Oct 13, 2015 3:09 pm
Well you both didnt understand me at all, im not black mailing anyone!
You said it wont ever be added so im simply saying then i dont need to buy this anymore. (dont see how thats blackmailing! why should someone buy something thats no longer suitable to then?)
i didnt mean it like if you dont add it then your a bunch of a**holes and im not paying
Sorry if it sounded that way...to you
As SKAGON said about the 256x256 icons would look tiny, thats what i have atm thats why i only asked if it could get added, when running on my 4k tv they look tiny that i cant read them
Users browsing this forum: Apple [Bot], Google [Bot] and 17 guests
