 Post subject: Start Menu Organizer question
PostPosted: Wed Jun 03, 2015 4:06 am
I installed the registered version of Xtreme, without un-installing the shareware version... this was as recommended by the readme file. Most things are working fine. However, when I open Start Menu Organizer, it is still the freeware version, not SMO Pro... I thought this version came with SMO Pro?? Do I need to download that separately?
 Post subject: Re: Start Menu Organizer question
PostPosted: Wed Jun 03, 2015 5:25 am
Are you sure it's not the Pro version? It should detect your Xtreme license key automatically and change itself to the Pro version (it will say 'Pro' on the main dialog itself).
If not, check the folder path of the shortcut you are using to launch it and compare it with the path used for the Winstep Xtreme shortcut. You might run into this problem if you installed Xtreme multiple times onto different folders (or if you downloaded the stand-alone version of the SMO and installed it onto a different folder - Xtreme already comes with it so you should not do this).
Also, make sure Xtreme is properly registered - it will say so at the bottom of NextSTART's and WorkShelf About tabs in Preferences.
PostPosted: Wed Jun 03, 2015 2:41 pm
Aha!! my bad... I had forgotten to apply the key file after I installed the registered package!! All is fine now, thanks!!
Users browsing this forum: No registered users and 88 guests
