 Post subject: Nexus steals app focus
PostPosted: Sat Apr 11, 2015 12:02 pm
I have a search app url on a dock. If I click it and leave a mouse pointer over a dock, my search app loses its focus and I can't type. Is it possible to change Nexus behavior?
 Post subject: Re: Nexus steals app focus
PostPosted: Sat Apr 11, 2015 2:33 pm
2 things to check, maybe : in dock properties / Bebavior / Advanced, see if "Popup deck on mouseover" is unchecked, and (if that fits your needs), activate "Hide the dock after launching and application"
There's probably something anyway, I just checked on mine : the launched application does have the focus, even if I let my mouse over the dock.
PostPosted: Sat Apr 11, 2015 6:33 pm
Skyfire76 wrote:
"Popup deck on mouseover" is unchecked.
Thanks a lot, that solved my problem. Why do someone need to popup deck on mouseover?
PostPosted: Tue Jun 02, 2015 3:41 am
If some people didn't find that option useful, it would not be there.
What works for you might not work for others and vice-versa - the good thing about Nexus is that it has the options for you to customize it the way *you* want it to work. :)
Users browsing this forum: No registered users and 75 guests
