 Post subject: Voice creator from TTS && voices packs examples
PostPosted: Tue Dec 02, 2014 12:49 pm
Hi there
Merry Christmas: voices are here.
The archive named "#WinstepVoiceCreator.7z" contains a CMD script I made to generate automatically the WAVs. This will be useful if you wanna create your own stuff. I know there are rooms for improvements but... ima lazy you know...
The CMD uses
- DSpeech to generate the WAVs
- generated from lotsa .txt files I created (and that you can mass edit using Notepad++ for example)
- that have their silences removed using SoX
See ya later aligator :mrgreen:
Users browsing this forum: GPT [Bot], Majestic-12 [Bot] and 41 guests
