 Post subject: WorkShelf Box After Locked Screen
PostPosted: Wed Aug 06, 2014 7:56 pm
A WorkShelf box has started to appear after I unlock my computer.
If I close Nexus Ultimate and restart it the box disappears. If I lock the computer and then sign in, it appears again.
I am running Windows 7 Pro.
Does anyone know what is going on ?
Thanks,
 Post subject: Re: WorkShelf Box After Locked Screen
PostPosted: Thu Aug 07, 2014 3:23 am
Did this only start happening recently?
PostPosted: Thu Aug 07, 2014 12:13 pm
No. It started happening some time back, around half a year ago. All I do is drag the box below the windows taskbar.
PostPosted: Thu Aug 07, 2014 12:52 pm
But it didn't happen when you first installed Nexus Ultimate, right?
PostPosted: Thu Aug 07, 2014 1:29 pm
You are correct. I had been using Nexus Ultimate for a long time before the WorkShelf box appeared.
PostPosted: Thu Aug 14, 2014 3:17 pm
I guess there is nothing I can try to fix this.
PostPosted: Thu Aug 14, 2014 10:32 pm
Sorry... the problem is that I have no idea what could be causing this either.
That empty window seems to be Nexus 'control window', but it is set to invisible, so you shouldn't be able to see it at all. Looks like something you installed on your PC later is turning the window visible when you unlock your computer - but what?
PostPosted: Fri Mar 06, 2015 9:10 pm
The email Client Lotus Notes seems to be triggering the visibility of the WorkShelf box after resumption from the Locked Screen.
Users browsing this forum: Bing [Bot], GPT [Bot] and 67 guests
