 Post subject: Right-click system tray icons
PostPosted: Thu Jul 17, 2014 4:54 pm
I do not know if this is a problem with Nexus Dock or the application itself. I have at least 2 applications that do not respond to rigjht-clicks on their system tray icons on the dock. They do respond when right-clicking on the system tray icon of the Windows taskbar. The applications are Free Download Manager and 360 Total Security. Any help is greatly appreciated.
 Post subject: Re: Right-click system tray icons
PostPosted: Thu Jul 17, 2014 8:49 pm
My guess is that those two applications are not responding to right clicks in a standard way. The system tray in Nexus is independent from the real Windows systray (kind of emulates it) and therefore 'passes through' mouse clicks to the applications themselves in a standard way.
Not having access to the actual Windows code that deals with the Windows systray, Nexus reverse-engineered the systray behavior, and might therefore be doing something slightly different from what Windows does - something which those applications rely on.
Left clicking those icons works normally, right?
PostPosted: Fri Jul 18, 2014 12:49 am
Left-click Free Download Manager icon works correctly (brings up the GUI). Left-click 360 Total Security icon has no effect (it should also open the GUI). In this case, I just run the executable again in order to see the interface. It's no show stopper. Thanks for all your hard work on Nexus Dock. It's awesome!
Users browsing this forum: Apple [Bot], winstep and 18 guests
