 Post subject: recycler module crashing
PostPosted: Wed Feb 05, 2014 9:38 pm
Hi,I have been trying out the free nexus version of the dock and everytime I drag something into the recycle bin module my laptop crashes.
I removed it from the dock and just use windows recycle bin but was wondering if this is a bug that needs fixed?
I would rather have the recycler module in the dock and get rid of the desktop icon
 Post subject: Re: recycler module crashing
PostPosted: Thu Feb 06, 2014 1:14 am
I don't believe this has been ever reported before. If you could provide some more information, like what kind of laptop, which version of Windows, 32 or 64-bit, what other programmes are running, etc., it would help.
Also, it could be some antivirus or other programme causing the crash.
PostPosted: Thu Feb 06, 2014 1:25 am
hi I am using a dell e5420 laptop with windows 7 64bit and running zonealarm pro firewall and anti virus.
I have no other applications running when I drag something into the recycler my laptop just freezes up.
PostPosted: Thu Feb 06, 2014 4:51 am
Hi,I have made my desktop recycle bin larger therefore don't need to use the module in the dock anyway so everythings ok.
thanks for trying to help though.
PostPosted: Thu Feb 06, 2014 3:16 pm
Hi. I've forwarded the issue to the programmer, so we'll see if he can replicate it.
For the time being, though, I suppose you could try to (temporarily) disable Zone Alarm and see if the problem persists.
As I have indicated, this is the first time a problem like this has been reported, so it may just be your computer and some minor settings peculiarity or minor problem that has gone unnoticed up until now, and it just happened to manifest itself by freezing Nexus.
By the way, have you any indication as to which programme it is that freezes the computer? Is it Nexus itself, Windows Explorer, Zone Alarm or something else?
Users browsing this forum: Amazon [Bot], GPT [Bot] and 59 guests
