 Post subject: Sub-Dock gets zorched
PostPosted: Mon Jan 06, 2014 6:15 am
Every once in a while, I lose an entire sub-dock. I'll click on the main dock item to open the sub-dock. Then, I'll click on a sub-dock item to open it. The next thing I know, the sub-dock is gone. The main dock item is gone, but replaced with a random item from the sub-dock (which may or may not have been the one that I clicked on).
The one sub-dock item that survives may or may not act correctly. When it doesn't act correctly, I'm sometimes able to change its type to a sub-dock (but not usually). Once, I was able to restore the sub-dock doing that, but have had no luck since.
So, is there any way to keep from zorching my sub-dock. Or, is there a way to restore the sub-dock items that got zorched?
 Post subject: Re: Sub-Dock gets zorched
PostPosted: Mon Jan 06, 2014 7:23 pm
Happened to me also in the beginning. Usually when you click on an item while the mouse is still moving a bit, which seems to invoke the drag and drop functionality of Winstep.
My advice:
1) Check 'Lock icons and prevent them from being dragged' in General tab under Miscellaneous Options. Only uncheck this temporarily if you want to drag items around.
2) Make a backup of your settings (Advanced tab), so you can restore your settings again (same tab) if something still goes wrong. This takes less time than restoring your items manually.
PostPosted: Wed Jan 08, 2014 6:46 am
Thanks. That's exactly what I was looking for.
