 Post subject: Weather Module, invalid location
PostPosted: Wed Nov 13, 2013 3:21 pm
I just installed the 12.02 version hoping it would solve this problem. It didn't. I cannot get the weather. I get invalid location.This has been going on for several weeks. Attached screen shot of error message. Help please.
 Post subject: Re: Weather Module, invalid location
PostPosted: Thu Nov 14, 2013 7:22 am
You're not alone. Something is going on. It could be one or more of the sites responsible for the information, a cache cleaning program like CCleaner or a security program blocking it.
I doubt it has anything to do with the module itself. I've been having a similar issue for about a week or so.
If I switch to a different city other than the one I use it works fine, hence why I suspect it could possibly be the latter two reasons I gave.
PostPosted: Thu Nov 14, 2013 1:38 pm
ccleaner and the like don't touch winstep, and once it's allowed through your firewall it's set.
PostPosted: Thu Nov 14, 2013 4:31 pm
Hey Chucky, its been a while. The reason I brought those up as possible secondary causes is that I recently updated CCleaner and my security programs update on a regular basis.
The weather module information stopped displaying and showed the invalid location error after using CCleaner. It could be just a coincidence.
As far as the security programs...once in a blue moon (after an update) they might flag something as malicious and fully or partially block something that should be white-listed that wasn't blocked previously.
It's happened on several occasions with Winstep programs. Obviously the false-positives aren't Jorge's fault. I remember quite some time ago there was an issue with a few security programs dragging their feet about wihite-listing the info submitted to them by Jorge.
PostPosted: Sat Dec 07, 2013 7:10 am
I was getting the same issue. I tried switching cities and it was still happening. I found the METAR code for my town and put that in and it worked. So it seems to be weather.com related.
PostPosted: Sat Dec 07, 2013 6:48 pm
Yes, it seem's the weather.com forecast stopped working (for Winstep) On my Linux System weather Apps. based on Weather.com forecast work fine.
PostPosted: Mon Jan 20, 2014 9:52 am
Hello, how to fix it has been over two months that it lasts with weather.com.
PostPosted: Mon Jan 20, 2014 9:58 am
until I use the Weather application pane windows but it is not top
PostPosted: Mon Jan 20, 2014 9:37 pm
Can you please restate the post. I don't understand.
Users browsing this forum: Majestic-12 [Bot] and 12 guests
