Board index : Winstep Forums : General Discussion  [ 31 posts ] Go to page Previous  1, 2, 3  Next
 Post subject: Re: Winstep Xtreme-Planet Background
PostPosted: Sat Aug 25, 2012 4:57 pm
ChuckysChild wrote:
i recommend bb flashback. q up the music you want, start your recording, and then start you music. very easy to upload to youtube once done.
I ended up using a combination of software already on my computer along with YouTube's Video Editor. You weren't the only one requesting music. :)
PostPosted: Sat Aug 25, 2012 5:05 pm
Okay everyone, because of popular demand, a third video is available complete with music. It's a merged video from the first two videos I made.
The title of the video is Winstep Xtreme Planet Background Combined with Audio.
http://www.youtube.com/watch?v=wHWzlo0oFbA
Unfortunately, if you're located in Germany you won't be able to view it because of something to do with rights with the songs.
PostPosted: Tue Aug 28, 2012 1:15 pm
Windy, sorry for not getting back to you sooner. i had a issue with my comp that i've been slowly fixing. the new vid looks great. glade youtube has the tools that you need. and glad that it's only one country where you can't use the music.
PostPosted: Thu Sep 27, 2012 1:37 pm
I've updated the link to the 1920x1080 background on the video which as at the beginning of this thread.
PostPosted: Fri May 31, 2013 2:44 pm
I've made an exhaustive list of screenshots that took a lot of time (which I normally don't have) to compile to show the pertinent settings needed to accomplish the bump settings and a few other ones for my configuration.
I will start from right to left since the menus open with the far most right tab selected.
The screenshots should help to clear up confusion while using Winstep Xtreme:
1) NextSTART--Accessed via Ctrl + F12 or double left-click the NextSTART icon on the System Tray which looks like a computer monitor, or right-click the Nexus icon > put the cursor on the context menu title bar where it reads: NeXus, and has the three buttons to min, max and close the context menu > middle-click (which for people not familiar is to press down on the mouse wheel if you have one. I don't remember if it's the default since I've changed it a few times). If nothing happens, try a left or double left-click. If that doesn't work try a right-click > Settings > Preferences.
2) WorkShelf--Accessed via Ctrl + F11 or right-click the Nexus icon on the Dock > Preferences, or, right-click WorksShelf and then select whatever you want from the context menu.
3) Dock-Bottom. I'll only post the bottom Dock info since the other two are the same except for minor differences like which side of the screen it's set to dock on, and which side to bump.
Very importantly, if I don't mention/or post a function that is in the screenshot, that means it has no significance as far as these settings and are usually minor in nature and could be a matter of taste or in my opinion, best left with the default settings.
NextSTART
Advanced option under Themes tab
PostPosted: Fri May 31, 2013 2:50 pm
Edit option
PostPosted: Fri May 31, 2013 2:56 pm
Edit Option
Edit option
PostPosted: Fri May 31, 2013 3:07 pm
Edit option > Next > Next
Edit option
PostPosted: Fri May 31, 2013 3:12 pm
Edit option >Next > Next
Edit option
PostPosted: Fri May 31, 2013 3:21 pm
Edit option > Next
The rest that are enabled in the Hotspot list are the same except the bump activation so I will not post those.
As far as the Taskbar tab, I have everything unchecked because I use the Windows taskbar.
PostPosted: Fri May 31, 2013 3:27 pm
Menu Titlebar Actions option
Advanced option
PostPosted: Fri May 31, 2013 3:36 pm
WorkShelf
More Options
WorkShelf-Shelf Preferences-General 2-More Options.png [ 72.96 KiB | Viewed 29872 times ]
PostPosted: Fri May 31, 2013 3:52 pm
Advanced option
VERY IMPORTANT! THE CLOCK MUST STAY ENABLED OR THE BUMP SETTINGS WILL NOT WORK CORRECTLY. TO MAKE THE CLOCK PRACTICALLY INVISIBLE, RIGHT-CLICK ON IT > SCALE > 10%.
In pull-down list
PostPosted: Fri May 31, 2013 4:19 pm
More Options
WorkShelf-Shelf Preferences-Modules 3-Recycler-More Options.png [ 72.21 KiB | Viewed 29871 times ]
PostPosted: Fri May 31, 2013 4:27 pm
Dock Properties
Edge Bump Settings
Dock Properties-Bottom-Behavior 2-Edge Bump Settings.png [ 73.98 KiB | Viewed 29871 times ]
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 31 posts ] Go to page Previous  1, 2, 3  Next
Users browsing this forum: Amazon [Bot], Google [Bot], GPT [Bot] and 58 guests
