 Post subject: Quick Question
PostPosted: Wed Sep 06, 2006 4:24 pm
Is it possible to Collapse/Un-Collapse the NS StartBar with the keyboard? I can't find an internal command to create a hotspot. Am I missing something?
Thanks,
KRomig
PostPosted: Wed Sep 06, 2006 5:29 pm
Collapse/un-collapse the NextSTART startbar? I didn't even know someone was actually using this feature. :D
Sadly the answer is no, currently there is no way to do this via the keyboard.
PostPosted: Wed Sep 06, 2006 8:29 pm
I am constantly playing with my system configuration. I had never used it, but thought I would set it up. The lack of keyboard control makes it less appealing to me.
You seem to have adjusted the ALT-key issues in WS with the latest beta. Yipppe! Thanks!
KRomig
PostPosted: Fri Sep 08, 2006 11:52 am
[quote="KRomigYou seem to have adjusted the ALT-key issues in WS with the latest beta. Yipppe! Thanks![/quote]
Told ya I would! :wink:
Users browsing this forum: Amazon [Bot], Google [Bot], Google Adsense [Bot] and 49 guests
