 Post subject: Some questions
PostPosted: Mon Jan 07, 2013 2:26 pm
Hi all! I'm new user of Winstep and i'm trying the trial version of Winstep Xtreme.
I've some questions about weather module.
The First question is: Where is the installation folder of this module?
The second question is: Can I use another weather url in this module, since my city is not listed?
I apologize for my bad English.
Thank you
FreeRaider
 Post subject: Re: Some questions
PostPosted: Mon Jan 07, 2013 2:44 pm
i hope you enjoy winstep as much as most of us do. as for your questions i personally don't use the gadgets so i really can't help, but i'm hoping bumping this will get skagon or windy's attention. either one of them should be able to help you out.
PostPosted: Mon Jan 07, 2013 7:42 pm
Winstep modules are integrated with the application itself - i.e.; they are NOT separate executables or DLLs.
Don't change the URLs since info from each specific URL is parsed in a different way. You can change the Weather.com code for a location though, if you manage to find the Weather.com code for your city.
Alternatively you can simply select a known location closest to you.
What city and country are you located at?
Users browsing this forum: Amazon [Bot], Apple [Bot] and 33 guests
