 Post subject: Windows task bar: where is it?
PostPosted: Wed Nov 07, 2012 10:08 pm
I´m using Windows task bar hide option, but when I need it (remove a USB device, for instance) where can I found it??
 Post subject: Re: Windows task bar: where is it?
PostPosted: Thu Nov 08, 2012 12:23 am
exit winstep n taskbar will come back, otherwise check preferences
PostPosted: Thu Nov 08, 2012 10:11 am
OK. I can survive without task bar. And what about notification area? How to control my internet conection status? And the programs who runs in background and I need to know the status??
I found it! There is a lots of Preferences and I found it in Content Tab.
Thanks...
PostPosted: Fri Nov 09, 2012 1:09 am
yeah it'd be great if the options were condensed in a more organized format. all the possibilities are great though
also if you want to hide taskbar but want to manage your system tray, make a separate dock for just the system tray
PostPosted: Fri Nov 16, 2012 9:58 am
I admit it's not perfect, but considering Nexus is the most versatile dock in the market, with a ton of different settings, organizing all those settings in a way that makes sense to *everybody* is almost impossible.
For instance, he found the show system tray option in the Contents tab of Nexus Preferences. It make sense for it to be there, doesn't it? Still... :wink:
Users browsing this forum: Google [Bot], GPT [Bot] and 11 guests
