 Post subject: HELP...
PostPosted: Mon Oct 29, 2012 11:10 am
I need help. i am making some skins ... so my problem is that i do now how to edit the pictures...but i want to change the skin name...from where do i do that...
there are all the txt files there...do not now who to change so that i can put my nme skin there....
thanks.
 Post subject: Re: HELP...
PostPosted: Wed Nov 14, 2012 7:10 pm
You need to change the name of each one of those text files to your skin name. After that is done, open each one and look for the skin name in them, change those too. Simple, but a little time consuming. :)
While you are in the files, look for the author name too. Your name goes there. ;)
Users browsing this forum: Google [Bot], GPT [Bot] and 11 guests
