 Post subject: Get rid of arrow below dock place holder
PostPosted: Fri Oct 12, 2012 12:49 pm
Hello, I was wondering if there is a way to get rid of the small arrow which appears below any dock place holder. I don't like it, and I don't need it :).
I've looked through the options and didn't find one, but there are so many I may have missed it.
Can anybody help me? Thanks in advance.
 Post subject: Re: Get rid of arrow below dock place holder
PostPosted: Fri Oct 12, 2012 10:35 pm
Under Dock Properties - Appearance tab - near lower right corner - Un-check "Show indicator for on shortcuts to applications that are currently running"
PostPosted: Sat Oct 13, 2012 3:18 pm
That's already unchecked, but it's not what I'm talking about.
I'm talking about the small arrow that appears next to dock entries which are just containers for other dock entries.
PostPosted: Sat Oct 13, 2012 9:44 pm
In the Winstep/Themes directory goto the Theme you use.
In this Theme folder (of the theme you use) there may or may not be the following three files:
- nxSubC.png (arrow which is shown when icon is not selected)
- nxSubM.png (arrow which is shown mouse is on icon)
- nxSubO.png (arrow which is shown when subdock is opened)
Add (when not present) or replace (when present) these files. Use a fully transparent 16x16 bit png file for this, to make the arrow disappear.
Don't forget to reboot, so the changes are applied.
PostPosted: Sat Oct 13, 2012 9:51 pm
Thanks a lot, that's what I was looking for.
Users browsing this forum: Majestic-12 [Bot] and 38 guests
