 Post subject: Removing Winstep
PostPosted: Tue Sep 25, 2012 4:06 pm
Hey there i jsut bought a PC who has winstep in it but i deleted it , i restored the PC to previous date but apparantly it bought winstep back into it i cant delete it agian form control panel and now it has lock my dekstop and i cant change to window setting any help would be aprreciated
 Post subject: Re: Removing Winstep
PostPosted: Tue Sep 25, 2012 4:17 pm
If it's not in the Add/Remove Programs section of the Windows Control Panel, then you need to remove it manually.
First you need to exit all running Winstep applications. Once that is done, easiest way is to delete the C:\Program Files\Winstep\ folder and all it's contents (C:\Program Files (x86)\Winstep\ if you are running a 64 bit system).
PostPosted: Tue Sep 25, 2012 4:31 pm
HI thanks for quick reply the problem i m getting it when my window start winstep take over and on top of left side of screen i cant click it to exit the program it jsut bring up page to buy it , i wanna remove that section
PostPosted: Tue Sep 25, 2012 4:58 pm
Errrrr, in the page to buy it there is an Exit button at the bottom. :P
Alternatively, you can open the Windows Task Manager, go to the Processes tab and kill nextstart.exe and workshelf.exe.
PostPosted: Wed Sep 26, 2012 2:49 am
Hi, why would you remove such a wonderful gift??? Did you try it before removing it? I know everyone has their preferences, but in my opinion this is one time I feel I ought to interject my opinion because you're getting it for free!
By any chance do you know what Winstep product it is? I sure hope it isn't Xtreme, because if it is, you would really be looking a gift horse in the mouth.
Users browsing this forum: GPT [Bot] and 54 guests
