 Post subject: Issues Customizing Winstep Xtreme System Tray Icons
PostPosted: Thu Aug 09, 2012 2:52 am
Hello,
I am having trouble trying to customize the system tray icons in Winstep Xtreme. I have successfully changed icons before in the preferences, however the battery icon, action center icon, network icon and volume icons do not appear in the list when I attempt to change them. Is there a way to make them appear in that list or do I have to modify the system files for windows to get them changed?
I am running Version 12.2 of Winstep Xtreme in Windows 7 32-bit.
 Post subject: Re: Issues Customizing Winstep Xtreme System Tray Icons
PostPosted: Mon Aug 13, 2012 5:30 am
Check the Tray Exclusion list and make sure Windows Explorer is not listed. If it is, remove it, then disable automatic exclusion.
PostPosted: Thu Aug 16, 2012 9:57 pm
That did it. Thank you very much for the help.
PostPosted: Sun Aug 19, 2012 9:46 am
While I was able to successfully change the system tray icons after I restarted my computer all of the icons that I customized for explorer, such as the battery and volume icons, are now listed as "orphan." I'm not sure why this has happened. Any ideas?
PostPosted: Sun Aug 19, 2012 12:44 pm
That's because when Explorer was automatically added to the exclusion list (I wonder how that happened, by the way, it means it crossed a certain threshold of different tray icons) all Explorer system tray icons were deleted from the Winstep tray icon cache to save space.
Anyway, should be a non issue, the 'orphan' icons should be automatically re-assigned as WorkShelf 'sees' the real tray icons they are associated to again and adds them to the Winstep tray icon cache.
PostPosted: Mon Aug 20, 2012 4:44 pm
Well they haven't switched back yet so I'm not sure whats up with it. I'll experiment later today to see if I can get it working right again.
PostPosted: Tue Aug 21, 2012 10:21 am
Winstep Xtreme will need to 'see' the original systray images that were previously associated to the orphaned icons in order to automatically re-assign them again.
In other words, if you have a customized battery tray icon at half charge, your battery must go to half charge before that image is used again by the system, which in turns automatically re-assigns the associated customized icon.
Provided all the icons are being customized properly, I would not worry and would leave the orphaned icons alone. Eventually things will fall into place by themselves, or at least they should.
PostPosted: Tue Aug 28, 2012 12:16 am
For some reason Explorer got readded to the exclusion list. Once I removed it from the list everything was discovered again. Thank you for the help once again.
Users browsing this forum: Apple [Bot], Bing [Bot] and 60 guests
