 Post subject: Newbie question: possible to create Win 7 Start menu?
PostPosted: Thu Aug 09, 2012 1:46 am
While I'm sure Winstep goes far beyond this is there a way using either "WinStep Nexus" or "Start Menu Organizer" to create the traditional Win 7 Start Orb and Menu?
TIA,
Menumarker
P.S. If it could do that,I know a number of people that would gladly use it in place of the Windows 8 "Start" menu. (Personally, I am just fascinated by the options the WinStep products use.)
 Post subject: Re: Newbie question: possible to create Win 7 Start menu?
PostPosted: Thu Aug 09, 2012 11:45 am
Yes, it is built in. If you look at the screen shots it is the Windows icon next to the Nexus icon. I don't have Windows 8, but they should be the same.
PostPosted: Fri Aug 10, 2012 2:34 am
When you say it is built-in do you mean in "WinStep Nexus", or "Start Menu Organizer", or both?
Thanks.
PostPosted: Fri Aug 10, 2012 11:00 am
On the Nexus, have not used the orginizer.
Users browsing this forum: No registered users and 51 guests
