 Post subject: IRC ?? and 'video refresh' bug with extreme
PostPosted: Sat Jul 01, 2006 11:57 pm
evenin vectornut
well i just cannot find you on irc (irc.skwire.net\winstep) and i cannot run the new extreme. it caUSES oops. my screen to "refresh" every 5 seconds and when im in my file manager that is VERY annoying as the screen 'blanks' then shows me what is in my folders. its not so bad on broswer window or just the desktop . i am running these few apps:
WB5 (latest )
CC
vid card is teh RAdeon AIW pro 9700 catalyst 6.5 drivers
I have no problem with the old NS just the new extreme, yes i just upgraded and its still there.
anyone else?
helpor suggestions ?
s
PostPosted: Sun Jul 02, 2006 7:00 pm
Hi!
Winstep no longer supports an IRC channel.
I think your screen refreshing problem might have something to do with the new 'task snapshots' feature, although it is the first time I have heard of something as bad as that - buggy video drivers, perhaps? ATI is well known for this - great hardware, lousy drivers.
Anyway, you can test this out by opening WorkShelf's Shelf Icon Preferences and disabling the 'Show window snapshots' option in the Tasks Shelf section. Then open NextSTART's Tasklist and Systray Preferences and disable the 'Show Snapshots' option.
When you mention the screen refreshes every 5 seconds... is that the *whole* screen or just a specific application?
PostPosted: Mon Jul 03, 2006 2:14 am
Hi Jorge, well yes buggy video drivers but tell me, is there a ( hi end )card that doesnt have crummy drivers?? ;-) so yes sure it could be, ive had one hell of a time with these drivers and just got them installed properly, dont make me tellyou how much fun it wasnt or how much time it took.
i will do as you suggest with hte snapshot thing. I have reinstalled winstep 3 in hte mean time and now workshelf is crashing. i will uninstall ns 3 and install Xtreme .
Ill keep you posted Jorge adn thanks again.
sue
PostPosted: Tue Jul 11, 2006 12:29 am
Thanks Jorge, that did it.
s
from spamville verizon :)
PostPosted: Thu Jul 13, 2006 8:28 am
Which is a pity, since task snapshots are actually very nice... Try enabling them again when you upgrade your current video drivers to see if the problem is gone.
Users browsing this forum: Amazon [Bot], Google [Bot] and 96 guests
