 Post subject: Suddenly am unable to update :(
PostPosted: Mon Aug 06, 2012 7:44 pm
it starts the download but at about75% it says failed: file size mismatch
No clue why, had no problem before. :(
This is on my laptop.
Any suggestions?
Thanks, appreciate it.
 Post subject: Re: Suddenly am unable to update :(
PostPosted: Mon Aug 06, 2012 10:57 pm
Any suggestions?
not sure what is causing the problem for you but assuming you license covers the current version you can download the latest full version of whichever winstep product you are running through the following page. just install it right on top of your existing version.
http://www.winstep.net/index.asp
Users browsing this forum: GPT [Bot] and 25 guests
