 Post subject: proxy settings
PostPosted: Wed Jun 14, 2006 2:54 am
Is there a way of configuring the proxy settings? The Weather, Time modules and NS/WS can't connect to the internet (I'm behind a firewall).
thanks
bruce
PostPosted: Wed Jun 14, 2006 6:37 pm
WorkShelf and NextSTART automatically use the Proxy settings defined in IE (Tools->Connections->LAN Settings->Proxy Server). This is assuming you are using public beta 2 or later, of course.
As of next release you will also be able to define Proxy settings manually.
Users browsing this forum: Apple [Bot], Google [Bot] and 66 guests
