 Post subject: Reinstall question
PostPosted: Sun Jun 11, 2006 10:00 pm
How do I move my old NS/WS settings to a new install on a new HD?
WS tabs, icons etc?
PostPosted: Sun Jun 11, 2006 11:24 pm
You go to the General Preferences tab of BOTH applications and click on the Backup button. Once you're re-installed on the new HD, you click on the Restore button to retrive your settings from the backup files created.
PostPosted: Mon Jun 12, 2006 12:57 am
What if I've already done a new install and didn't backup?
PostPosted: Mon Jun 12, 2006 1:16 am
Then, unless you can somehow open the Windows Registry in the original drive and export the
HKEY_CURRENT_USER\Software\Winstep2000
key, I would say you are out of luck, sorry. You will have to re-build by hand.
PostPosted: Mon Jun 12, 2006 2:42 am
That's what I was afraid of. Thanks.
Users browsing this forum: Apple [Bot], Google [Bot] and 79 guests
