 Post subject: Systray issue in NS
PostPosted: Thu Apr 22, 2004 12:53 pm
Good day to you all.
Here is my little problem. Under preferences -> Tasklist and Systray Preferences.
When I choose "Bottom Right (or Left)" for the Systray Position it goes to the top right(or left).
When I choose "Top Right (or Left)" it moves to the bottom right (or left).
My Tops and Bottoms are backwards. :shock:
PostPosted: Fri Apr 23, 2004 7:13 pm
Let me also say this is when the systray is not locked onto the taskbar.
PostPosted: Tue May 25, 2004 9:13 pm
Sorry for the late reply Shawn.
Here it behaves as it should (top is top and bottom is bottom). Is anything peculiar about your display? Is anyone else seeing this?
PostPosted: Fri May 28, 2004 6:10 pm
No worries on the time it takes for replies. :D
I am running a Geforece 4 MX video card with Dual-displays (left-right).
Resolution is 1280x960
Here are a couple of pics (sorry they are a bit fuzzy, but hopefully still readable)
PostPosted: Fri May 28, 2004 7:46 pm
Ahem. Have you noticed your vertical offset? :shock: :lol:
PostPosted: Mon May 31, 2004 1:50 pm
i have also had this behaviour, i just ddragged the darn thing to where i wanted it. Reinstalling winderz helped this but my sys button still wont sstay on top so i can collapse the systray when its in the way .
im running xp pro with ati catalyst 4.5
sj
PostPosted: Mon May 31, 2004 2:59 pm
Guess I didn't explain myself properly. If the systray is at the bottom and you give it a positive vertical offset, the offset makes the systray go UP (and down if you set the origin to be at the top).
Set the systray vertical offset to 0 and it will behave as it should.
PostPosted: Tue Jun 01, 2004 1:04 pm
Very Nice! That worked exactly! Thank you very much again.
FYI, I had never manually changed the offset value. I am not sure how that value managed to get that high. I will see if I can manage it again.
PostPosted: Tue Jun 01, 2004 2:50 pm
Dragging the systray with the mouse will do that (it's supposed to).
PostPosted: Tue Jun 01, 2004 5:27 pm
I noticed that. :) I am trying to find out how I managed to get it to such a large number. :?
Users browsing this forum: Amazon [Bot], Picco14 and 53 guests
