 Post subject: Please help with Active Windows
PostPosted: Tue May 25, 2004 7:34 pm
I can change my start menu and wallpaper...
But my active windows and inactive windows stay the same old colour...
how would you change it to go with the theme you choose?
PostPosted: Tue May 25, 2004 8:38 pm
If you are talking about Explorer windows, NextSTART does not skin them - you will need a program like WindowBlinds or StyleXP to do that.
If you are talking about NextSTART menus, well, that depends on the theme you are using.
PostPosted: Wed May 26, 2004 4:57 am
thanks....
Users browsing this forum: No registered users and 62 guests
