Board index : Winstep Forums : General Discussion  [ 22 posts ] Go to page Previous  1, 2
 Post subject: Re: BitDefender and Nexus Ultimate
PostPosted: Mon Jul 09, 2012 4:18 am
@Windy,
I tried both settings with the same result. The only thing that makes the sub-dock appear in front is the Alt-Tab or having ANY other window active instead of the desktop.
Thanks,
Grouch
Windows 10 Pro[x64]
Nexus Ultimate 20.10.1154
Antivirus: Windows Defender
PostPosted: Mon Jul 09, 2012 11:29 am
Windy wrote:
P.S. What I found is sometimes you have to turn off all security programs when installing certain programs. I set up several friends computers that purchased Xtreme and the first thing I do is turn off the security programs before installing it.
i never turn off the security program when installing winstep or any other program, in fact i always ignore the warning to turn everything when installing a program. i have built and done all the installs on more computers than i care to thank about, and with the exception of programs that give you no choice but to shutdown this / that / or the other thing i have never turned off anything to install another program.
PostPosted: Tue Jul 10, 2012 2:05 am
Grouch wrote:
@Windy,
Thanks,
Grouch
I'm scratching my head on this one. The only thing I didn't change when I tested it out was that my dock was not set to hide. Maybe you can try changing it so it doesn't hide and see if that works.
I only do this with programs that I'm 100% sure doesn't have malware. There are a lot of security programs that incorrectly block certain functions of a program causing the newly installed program to have glitches. I've experienced this countless times.
PostPosted: Tue Jul 10, 2012 5:55 am
Grouch wrote:
It SEEMS that there is an off-by-one error in the z-levels of "NeXuS vs. Desktop" that Alt-Tab corrects. It is not just the sub-dock that hides behind the parent. Any "Dock entry properties" dialog has to be dragged out from behind the dock in order to click the "OK" or "Cancel" buttons.
As many other Windows customization developers will tell you, z-order problems are a pain-in-the-bottom to solve properly, *especially* when you are dealing with a raised desktop.
Microsoft does NOT want other applications even being aware that the desktop has been raised. As such, they make it very difficult to work around it.
When you raise the desktop, Windows does not signal this to other applications in any way, but it does some very special under-the-hood things to it and to the screen objects that belong to the desktop. Mess with this and you can get some very strange things happening, such as the Windows taskbar disappearing when you click somewhere else.
The only real solution for a raised desktop is temporarily setting all of you windows to be always-on-top while a 'raised desktop' is in effect. This can be problematic if you then proceed to work normally for some time in this mode, because normally bringing another application forward would cancel a 'raised desktop'. On the other hand, canceling this mode is not what you want when dealing with the dock.
Trying to work around this can create a host of conflicts - bottom line is that Windows was not designed to have the user working on a 3rd party application (that not the desktop itself and desktop bound objects) while the desktop is raised.
As for the invisible BitDefender window appearing, I really have no idea what might be causing it, sorry...
PostPosted: Tue Jul 10, 2012 12:02 pm
Jorge,
My programming experience is limited to mainframes (remember them?), so I don't know what idiosyncrasies Windows has. If the Alt-Tab trick works to prevent the problem, is there some way to simulate it when you "onmouseover" the dock? It doesn't appear to be a toggle, so doing it shouldn't affect anyone.
When I had stripped the PC of everything except Nexus, the only thing left would be a user-profile setting that could be affecting only my PC. I can't think of anything that would affect z-order.
I apologize for my hounding you on this topic, but the results are affecting three other applications. Two of these require a reboot to correct, the third just requires jumping through hoops because the app doesn't behave normally.
Thanks for your patience,
Grouch
Windows 10 Pro[x64]
PostPosted: Wed Jul 11, 2012 1:35 am
I did try it with the dock left visible and still got the same results. That would still leave me with the dock taking up real estate like a shelf. That is why I like the dock that dismisses itself and hides.
I stress the fact that you have to click on an empty spot on the desktop before hovering over the dock icon to bring up the sub-dock. I've gotten in the habit of clicking on the desktop to deselect any icons that may be selected. Too many times have I clicked on an icon and dragged it to the trash not noticing that another icon was selected. I wound up deleting both items.
Thanks,
Grouch
Windows 10 Pro[x64]
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 22 posts ] Go to page Previous  1, 2
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 82 guests
