 Post subject: Nexus Ultimate: question about menu
PostPosted: Wed Jun 20, 2012 1:24 pm
Hello everybody,
I have bought Nexus Ultimate and needing an answer to this question: it is possible to disable the right-click menu?
I would like all menus disabled, and that preference window could be accessible ONLY using the keyboard shortcut (i.e. Ctrl+F11)
Thank you
 Post subject: Re: Nexus Ultimate: question about menu
PostPosted: Wed Jun 27, 2012 11:20 am
Ooops, sorry for the late reply, apparently I skipped your post. :(
No, there is no way to completely disable the right-click menu or limit access to Preferences. Were you thinking of installing Nexus Ultimate on some kind of Kiosk or Internet Cafe?
PostPosted: Thu Jun 28, 2012 1:27 pm
No, but is something related to an application where i don't want the end user to change settings.
Ok, in any case thank You, i will try to find another solution
PostPosted: Fri Apr 12, 2013 3:38 pm
Hello, is there some change in the behaviour of right-click ?
Is it possible to disable it and replace by a keyboard shortcut?
Thank You
Users browsing this forum: GPT [Bot] and 72 guests
