 Post subject: Are Winstep themes supposed to work on Windows windows??
PostPosted: Mon May 14, 2012 7:27 pm
I get a nice taskbar/tasklist with Winstep themes, but it does not apply to normal Windows applications, such as cmd.exe, Explorer, etc. Is this expected? Or have I got some option set wrong?
 Post subject: Re: Are Winstep themes supposed to work on Windows windows??
PostPosted: Mon May 14, 2012 8:00 pm
this is normal. you are thinking about custom windows themes that may skin everything in windows.
PostPosted: Thu May 17, 2012 9:54 pm
As Chucky said, Winstep only skins itself. If you want to skin the OS, you will need an application like Stardock WindowBlinds.
PostPosted: Thu May 17, 2012 10:19 pm
jorge he does not need windowblinds to skin windows. go to
http://virtualcustoms.net/forum.php
or
http://www.creativx.net/
PostPosted: Fri May 18, 2012 8:22 pm
Wow, ChuckysChild, thanks for those leads!! Looks like I'll have some fun playing with all those options. I really don't like WindowBlinds all that much, just as soon not deal with it.
Users browsing this forum: Amazon [Bot], GPT [Bot] and 65 guests
