 Post subject: Keyboard Navigation?
PostPosted: Mon May 14, 2012 3:30 pm
Is it possible to activate/navigate Nexus via the keyboard? I played around with it and I couldn't find any settings for it, but reviews for this program list keyboard navigation as a feature. Am I just mis-informed or is there something I'm missing?
 Post subject: Re: Keyboard Navigation?
PostPosted: Thu May 17, 2012 10:01 pm
Not sure what your expectations for keyboard navigation under Nexus are. :D
If you mean launching applications through the keyboard, just associate a hotkey to each of the shortcuts in the dock. You can do this by right clicking a shortcut, selecting Dock Entry Properties, then setting the Hotkey field to a key combination of your choice.
Users browsing this forum: techlobo and 45 guests
