 Post subject: Nexus freeze at the screen!
PostPosted: Tue May 08, 2012 12:03 pm
Hi, I use nexus for months and these days he begin to freeze and only start to behave normally when I change one config(may be align to the center). This occur everytime when I enter in windows 8 cp metro style start but the program was fully functional a week ago with the same system!
 Post subject: Re: Nexus freeze at the screen!
PostPosted: Tue May 08, 2012 12:15 pm
If Nexus was behaving normally before but now it isn't, then it must be because of some change you made to your system. Perhaps an update to your AV/Security software?
Problem is that Windows 8 is still in beta, which means MS can change whatever it wants at any time. As such, it is not worth investing a lot of resources fixing a problem that might not even be there in the next beta (and this assuming this might be a Windows 8 compatibility problem, which I'm pretty sure it's not).
I would really like to help you more, but, at this point, it is really up to you to try and figure out what is causing/has caused this issue, sorry...
PostPosted: Tue May 08, 2012 12:18 pm
Thanks! I'll try to clean the nexus configuration and try again
PostPosted: Tue May 08, 2012 12:24 pm
Ah, one question: I imagine what you are saying is that Nexus is frozen when you return from the Metro UI, right? Have you tried waiting a little bit to see if Nexus unfreezes itself?
PostPosted: Tue May 08, 2012 12:46 pm
Nexus stuck the open windows is still functional but nothing changes(in minutes at least). I changed the configuration of auto hide back to slide(the one I was using previously) instead of fade out and now appears that nexus is back to normal! when I go to metro UI nexus slide in even when I don't touch the border(I can only see nexus appearing on the transition to metro UI and back to desktop).
Users browsing this forum: Amazon [Bot], Google [Bot], GPT [Bot] and 85 guests
