 Post subject: Installation issue of Xtreme 12.2 over Nexus 12.2
PostPosted: Sat Apr 07, 2012 1:16 pm
I installed Nexus 12.2 and later the same day Xtreme 12.2.
I now have two bars at the top center, one for Xtreme and one for Nexus. When I bought a license and installed it it actually showed two installs. In control panel it only shows that Xtreme is installed.
1. I don't want two of my licences taken for one machine.
2. I would like to get rid of the Nexus bar.
Task Manager shows Nextart.exe and Nexus.exe
What is the best way to accomplish this? :?:
 Post subject: Re: Installation issue of Xtreme 12.2 over Nexus 12.2
PostPosted: Sat Apr 07, 2012 2:50 pm
The Winstep Xtreme install overwrites the Nexus install in Add/Remove Programs.
Quickest (and dirtiest) way to fix this is to exit Nexus then delete nexus.exe from 'C:\Program Files (x86)\Winstep\'
PostPosted: Sun Apr 08, 2012 10:42 pm
Thanks worked fine. I assume I will only be charged on license for thsi computer.
:D
Have a great day.
Noah
Users browsing this forum: Amazon [Bot], Google [Bot] and 68 guests
