 Post subject: Minor Problem
PostPosted: Thu Apr 05, 2012 1:42 am
If I set Dock Properties > Behavior > Auto-hide Mode: to "No Animation" the setting won't stick. I can change that setting, click ok to leave the dialog & it works but if I restart Nexus it resets to "Slide" every time. If I change it to "Fly Out" or one of the others the setting will stick. Like the title states it's a minor problem but it's a little annoying.
Nexus Ultimate v12.2
Windows XP Home, SP3
Any ideas?
The following statement is false.
The preceding statement is true.
 Post subject: Re: Minor Problem
PostPosted: Thu Apr 05, 2012 2:03 am
Bug, sorry, fixed for next release.
PostPosted: Thu Apr 05, 2012 2:08 am
Alrighty then. I hope that's before 4/28 :)
PostPosted: Thu Apr 05, 2012 2:20 am
Ahaha. :D
Hey, even if it is after, I'm pretty sure you will still want all the goodies that will be added to Winstep applications in the next 365 days, right? So there's no point in letting your upgrade subscription elapse... ;-)
With 3-4 releases per year, each packed with new features, I believe you will agree that you're getting more than your money's worth. :D
PostPosted: Thu Apr 05, 2012 9:12 am
Indeed, agreed. You know what, I never read the upgrade policy before today. I just read it & it costs less than I assumed :) It will be done. I was once an OD+ user and dumped them when they implemented Impulse, it was the best thing that ever happened to my dock situation.
Users browsing this forum: Google [Bot] and 56 guests
