 Post subject: Winstep and virtual desktops (Dexpot)
PostPosted: Sun Jul 10, 2011 2:33 pm
Hi all, amazing software and loving it.
I just got it and have it all set up but when I go to my other Dexpot desktops nothing is there. So I have been searching the forums for any help to make Winstep run on all desktop or at the very least transfer it to the next desktop I wish to use. Any help is appreciated, thanks...
Doc
 Post subject: Re: Winstep and virtual desktops (Dexpot)
PostPosted: Sun Jul 10, 2011 10:08 pm
Hi!
I've heard about Dexpot but I am not familiar with it. Maybe another Winstep user here in the forums is using it and could help you with it?
Does Dexpot have any function to make a particular window appear in all the Desktops?
PostPosted: Mon Jul 11, 2011 5:53 pm
I don't use dexpot, but I've used Yod'm 3D which had the option to transport windows from a desktop to another or to make a new clean desktop. I'm sure that even Dexpot has this ability, check a little the settings.
PostPosted: Wed Jul 13, 2011 5:47 am
Hi,
I have been using Dexpot for some months now on Vista x64. There is more than one way to accomplish what you want. If you right-click on the system tray icon and choose Desktop Rules, you can define a rule for Nexus Dock with an action of Copy to All Desktops. You can also assign hot-keys to copy/move windows to other/all desktops. As for myself, I have Nexus Dock set to come on top of other windows when the mouse cursor bumps the top of the screen. When I switch to another desktop, I can just bump the screen edge to bring Nexus Dock into view.
Unfortunately, help is a little sparse for Dexpot. I found a very minimalist tutorial here:
http://www.maximumpc.com/article/how-to ... _windows_7–integrated_virtual_desktops
If you have specific questions, you can post them in their forum in the support area. Replies are usually fairly prompt, so, you shouldn't have to wait long for an answer.
PostPosted: Sat Jul 16, 2011 6:15 pm
I found that if you switch to the screen you want in DEXPOT, and then activate WINSTEP (NEXUS) preferences and hit apply with no other changes, the bar pops up and stays on even when switching desktops. This works on every Dexpot screen
PostPosted: Fri Mar 09, 2012 10:01 am
Is it possible to play games within hosted virtual desktop, I never tried it?I think we would be able to play games as virtual desktops , but I would like to know more.
PostPosted: Fri Mar 09, 2012 10:16 am
Are you a spam bot or a real human?
PostPosted: Fri Mar 09, 2012 1:50 pm
it's a bot drop the ban hammer.
PostPosted: Fri Mar 16, 2012 5:22 am
Here's the way to do it, I tried this myself just now so I know it works.
In your Dexpot program folder there's a file called wechsel.ini Open it up and look for where it says [Exe], under that part put this line: Nexus.exe=sticky save and it should work.
PostPosted: Wed Mar 28, 2012 8:52 pm
File comment: Your file should look something like this.
Here's the way to do it on Nexus Ultimate 12.02: In your Dexpot program folder, there's a file called "wechsel.ini" (or "my wechsel.ini") (no quotes). Add these two lines under the part that says [EXE]:
Nexus-Ultimate.exe=sticky
WinstepXtreme.exe=sticky
Your file should look something like the one in the picture.
PostPosted: Wed Apr 04, 2012 8:25 pm
Hey,
It's not hard to have your Nexus Dock on all Desktops, using Dexpot.
Right Click on the Tray Icon of Dexpot and choose the Option "Assign Applications"
There you can decide on which Desktop running Applications should be, furthermore you can add other apps to the list and set on which one they should be.
greetz
Users browsing this forum: Google [Bot], GPT [Bot] and 78 guests
